Andy_K_Tuck
Sep 02, 2020Aspirant
Slow Speed and disconnects C6300
This morning my internet slowed down to a trickle and is now practically unusable on all of my devices. I spent hours on the phone with my ISP (Comcast) and they did several restarts, diagnostics che...
Sep 02, 2020Guru - Experienced User
do you have a screen snip of the cable connections page and the modem logs? attach them here.
Is it wired devices, wireless devices, or both having issues?
Any cable splitters, amplifiers, or attenuators in line? if so, remove them.
- Andy_K_TuckSep 11, 2020AspirantNot exactly sure how to find the logs. Hopefully what I attached is right. It’s slow with both WiFi and wired connection. No splitters, etc attached. If I do a reset it will work fine for about 20 mins, then it will slow down again (and the light with the little global starts blinking). If I plug my old modem router in it works fine so I don’t think it’s an ISP issue.
- plemansSep 11, 2020Guru - Experienced User
you got one of the right sections but you need more info. it should have the rest of the channels plus the upstream. That's key just as much as the downstream.
here's how to get logs
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
- Andy_K_TuckSep 11, 2020AspirantRest of the channels and upstream bonded channels
- Andy_K_TuckSep 11, 2020AspirantLogs
