DabbinBallZ
Jan 06, 2024Aspirant
Slow speed on my Nighthawk C7000v2
I spoke with my ISP and they have scheduled a tech to test the line as they are seeing low frequency on the line. Paying for 1 gig, used to get anywhere from 400-700 Mbps down depending on time of day, now I am getting 4-16 Mbps down. Any assistance in isolating the cause would be appreciated. I have a feeling it's the line but want to verify it's not my device before the tech arrives next week. Event log is below.
Ok,
So power levels are too low and all over the place. Power needs to come up and be with in 3db of each channel.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
You have a ton of correctables and uncorrectables that should be zero.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/Get a on site ISP tech out to review all this and get it working better.
Who is the ISP?
Please post a copy and paste of the modems connection status page data.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router- DabbinBallZAspirant
V1.03.01
ISP is Optimum
ownstream Bonded Channels (Partial Service) Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 17 657000000 Hz -7.3 dBmV 34 dB 0 0 2 Locked QAM256 1 561000000 Hz -7.8 dBmV 33.7 dB 0 0 3 Locked QAM256 2 567000000 Hz -6.3 dBmV 35.2 dB 0 0 4 Locked QAM256 3 573000000 Hz -5.6 dBmV 35.6 dB 0 0 5 Locked QAM256 12 627000000 Hz -2.8 dBmV 37.3 dB 0 0 6 Locked QAM256 13 633000000 Hz -3.3 dBmV 37.2 dB 0 0 7 Locked QAM256 14 639000000 Hz -4.7 dBmV 35.8 dB 0 0 8 Locked QAM256 15 645000000 Hz -6.2 dBmV 35.2 dB 0 0 9 Locked QAM256 16 651000000 Hz -7.4 dBmV 34.1 dB 0 0 10 Locked QAM256 18 663000000 Hz -6 dBmV 35 dB 0 0 11 Locked QAM256 19 669000000 Hz -5.4 dBmV 35 dB 0 0 12 Locked QAM256 20 675000000 Hz -9.1 dBmV 31.6 dB 403 0 13 Locked QAM256 21 681000000 Hz -13.7 dBmV 27.6 dB 75659269 3221598 14 Not Locked Unknown 22 687000000 Hz 0.0 dBmV 0.0 dB 0 0 15 Not Locked Unknown 23 693000000 Hz 0.0 dBmV 0.0 dB 0 0 16 Locked QAM256 24 699000000 Hz -13.6 dBmV 27.9 dB 14030911 5437 17 Locked QAM256 25 705000000 Hz -11.1 dBmV 30.3 dB 13 0 18 Locked QAM256 26 711000000 Hz -11.8 dBmV 29.8 dB 140 0 19 Locked QAM256 27 717000000 Hz -12.7 dBmV 29.1 dB 816 0 20 Locked QAM256 28 723000000 Hz -11.6 dBmV 30.3 dB 10 0 21 Locked QAM256 29 729000000 Hz -12.3 dBmV 29.3 dB 458 0 22 Locked QAM256 30 735000000 Hz -14.8 dBmV 27.1 dB 287803 1407 23 Locked QAM256 31 741000000 Hz -15.8 dBmV 26.1 dB 50223 189548 24 Not Locked Unknown 32 747000000 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 5 5120 Ksym/sec 38000000 Hz 37.8 dBmV 2 Locked ATDMA 6 5120 Ksym/sec 31600000 Hz 36.8 dBmV 3 Locked ATDMA 7 5120 Ksym/sec 25000000 Hz 36.3 dBmV 4 Locked ATDMA 8 2560 Ksym/sec 20200000 Hz 35.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV - FURRYe38Guru - Experienced User
Ok,
