MAYDAYTAY
Mar 21, 2022Tutor
Slow speeds with C7000V2
Hello, I am using a C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router on Firmware V1.03.03 with windows and I am not getting the correct download speeds. I tried looking through a lot of t...
Mar 21, 2022Guru - Experienced User
what device (computer/pc) are you testing with?
Have you checked your port statistics to see if you're connecting at gigabit speeds?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Do you have a screensnip of the cable connections page and event logs?
MAYDAYTAY
Mar 21, 2022Tutor
Is this what you need? I am using the Genie. Not sure where event logs or cable connections are. Let me know if you can see the picture or not. And I am using a desktop PC
