MAYDAYTAY
Mar 21, 2022Tutor
Slow speeds with C7000V2
Hello, I am using a C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router on Firmware V1.03.03 with windows and I am not getting the correct download speeds. I tried looking through a lot of t...
MAYDAYTAY
Mar 21, 2022Tutor
I had a sparklight guy come out today to test the connection and he was also getting slow speeds with his device from the router.
This is the current cable I am using. https://www.amazon.com/gp/product/B07QFDY7YC/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&th=1
MAYDAYTAY
Mar 21, 2022Tutor
I found the event log. Want a screen shot of it?
- plemansMar 21, 2022Guru - Experienced User
Your port statistics page is showing a connection speed of 100mbps.
If its not negotiating a gigabit connection, then you're not going to get faster speeds.
it could be the cable (which is why I said try a different one), it could be device you're testing with.All I know 100%, is that your ethernet connection is only 100mbps.
That's going to limit your speed.
- plemansMar 21, 2022Guru - Experienced UserAlso, your 2.4ghz speeds are set at 54mbps. did you disable wmm or using an older wifi standard? Or did you set the speeds on it down?
- MAYDAYTAYMar 22, 2022Tutor
I turned on extended upstream transmit power to see what it would be and it appears to have fixed the issue for now.
