MAYDAYTAY
Mar 21, 2022Tutor
Slow speeds with C7000V2
Hello, I am using a C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router on Firmware V1.03.03 with windows and I am not getting the correct download speeds. I tried looking through a lot of t...
Mar 21, 2022Guru - Experienced User
Your port statistics page is showing a connection speed of 100mbps.
If its not negotiating a gigabit connection, then you're not going to get faster speeds.
it could be the cable (which is why I said try a different one), it could be device you're testing with.
All I know 100%, is that your ethernet connection is only 100mbps.
That's going to limit your speed.
Also, your 2.4ghz speeds are set at 54mbps. did you disable wmm or using an older wifi standard? Or did you set the speeds on it down?
- MAYDAYTAYMar 22, 2022Tutor
I turned on extended upstream transmit power to see what it would be and it appears to have fixed the issue for now.
- baisanchezJul 27, 2022Aspiranthow do you turn on extended upstream transmit power
