Batsofaqua's avatar
Batsofaqua
Follower
Mar 20, 2017
Slow speeds with new N600 WiFi Cable Modem Router
I have just purchased the N600 Wifi Cable Modem Router to replace my old Comcast Xfinity modem in hopes of recieving a better internet connection. I have a PC located about 30 feet away with only one wall in the way. With the Comcast modem I was able to get speeds around 30mpbs (Im suppose to be getting 150mpbs) pretty consistently. Now with the N600 I am only able to get about 5mpbs. Is this something that can be fixed with some setting changes or is the N600 not worth it?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Batsofaqua
    Are you only getting 5mps on ethernet connections or are you testing this over the wifi?
    DarrenM
