vvildstar
Jan 21, 2021Aspirant
Slow upload speeds CM2000 vs CM1200
Hello All! I just tried to switch out our CM1200 for the new CM2000. We are on the Comcast/Xfinity 1G plan. The download speed seems to be similar between the two cable modems, however I am not...
Jan 21, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Post a copy and paste sample of the connections status page from the modem...
- vvildstarJan 21, 2021AspirantAppreciate the reply! I’ll reach out to the ISP tomorrow. It’s just weird because nothing should be wrong with the line or anything like that. The new modem is exactly where the old one is and I probably switched between the two 3 or 4 times tonight and the only thing that was different between the two is upload speed.
- FURRYe38Jan 21, 2021Guru - Experienced User
