AspenMB93
Jan 18, 2022Aspirant
Slow upload speeds on my CM1000v2
I have been averaging upload speeds between 0.5-5 Mbps. Download speeds are great, averaging 780-800mbps with Cox's Gigablast plan. I am currently using a CM1000v2 moden with a Nighthawk R6900P route...
Jan 19, 2022Guru - Experienced User
Your logs are showing line issues.
Got a screen snip of the cable connections page?
- AspenMB93Jan 20, 2022Aspirant
See below for cable connection tables:
Starting Frequency <tabindex=-1>Startup Procedure</tabindex=-1>
Procedure Status Comment Acquire Downstream Channel 381000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv4 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 37 381000000 Hz 2.7 dBmV 44.6 dB 1334438430 1 0 2 Locked QAM256 33 357000000 Hz 2.7 dBmV 44.1 dB 1332813476 0 0 3 Locked QAM256 34 363000000 Hz 2.7 dBmV 44.6 dB 1332820587 1 0 4 Locked QAM256 35 369000000 Hz 2.7 dBmV 44.1 dB 1332829348 0 0 5 Locked QAM256 36 375000000 Hz 2.8 dBmV 44.5 dB 1332855787 0 0 6 Locked QAM256 38 387000000 Hz 2.9 dBmV 44.7 dB 1332862300 1 0 7 Locked QAM256 39 393000000 Hz 3.1 dBmV 44.7 dB 1332868462 3 0 8 Locked QAM256 40 399000000 Hz 3.4 dBmV 44.9 dB 1332877388 4 0 9 Locked QAM256 41 405000000 Hz 3.8 dBmV 45.1 dB 1332882769 14 0 10 Locked QAM256 9 729000000 Hz 0.3 dBmV 40.7 dB 1365722977 14 0 11 Locked QAM256 10 735000000 Hz -0.3 dBmV 41.8 dB 1365729607 16 0 12 Locked QAM256 11 741000000 Hz -0.1 dBmV 42.6 dB 1365733376 25 0 13 Locked QAM256 12 747000000 Hz -0.3 dBmV 41.0 dB 1365736479 21 0 14 Locked QAM256 42 411000000 Hz 4.1 dBmV 44.9 dB 1332923163 4 0 15 Locked QAM256 14 759000000 Hz -0.7 dBmV 42.4 dB 1365744175 36 0 16 Locked QAM256 15 765000000 Hz -0.5 dBmV 42.5 dB 1365747951 19 0 17 Locked QAM256 16 771000000 Hz -1.3 dBmV 42.1 dB 1365749336 28 0 18 Locked QAM256 17 777000000 Hz -1.0 dBmV 42.3 dB 1365753969 34 0 19 Locked QAM256 18 783000000 Hz -0.7 dBmV 42.5 dB 1365757249 33 0 20 Locked QAM256 19 789000000 Hz -0.9 dBmV 42.5 dB 1365761720 37 0 21 Locked QAM256 20 795000000 Hz -0.9 dBmV 42.4 dB 1365765868 25 0 22 Locked QAM256 22 807000000 Hz -0.8 dBmV 42.7 dB 1365769310 16 0 23 Locked QAM256 23 813000000 Hz -1.6 dBmV 42.1 dB 1365773345 17 0 24 Locked QAM256 24 819000000 Hz -1.6 dBmV 42.1 dB 1365777183 13 0 25 Locked QAM256 25 825000000 Hz -2.0 dBmV 41.8 dB 1365780151 13 0 26 Locked QAM256 26 831000000 Hz -1.8 dBmV 42.1 dB 1365783876 17 0 27 Locked QAM256 27 837000000 Hz -1.7 dBmV 42.0 dB 1365789028 12 0 28 Locked QAM256 28 843000000 Hz -2.2 dBmV 41.8 dB 1365792260 10 0 29 Locked QAM256 45 429000000 Hz 4.0 dBmV 45.2 dB 1333037416 3 0 30 Locked QAM256 30 855000000 Hz -2.5 dBmV 41.6 dB 1365798789 12 0 31 Locked QAM256 31 861000000 Hz -3.1 dBmV 40.8 dB 1365799426 11 0 32 Locked QAM256 32 867000000 Hz -2.9 dBmV 41.3 dB 1365800819 3 0 <tabindex=-1>Upstream Bonded Channels (Partial Service)</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 36800000 Hz 42.8 dBmV 2 Locked ATDMA 2 30400000 Hz 42.8 dBmV 3 Locked ATDMA 3 24000000 Hz 43.3 dBmV 4 Locked ATDMA 4 17600000 Hz 43.5 dBmV 5 Locked ATDMA 5 60000000 Hz 36.0 dBmV 6 Locked ATDMA 6 67000000 Hz 37.5 dBmV 7 Locked ATDMA 7 74000000 Hz 39.8 dBmV 8 Locked ATDMA 8 81000000 Hz 35.3 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 159 300000000 Hz 2.5 dBmV 42.5 dB 1108 ~ 2987 3407239875 664915089 0 2 Not Locked 0 0 0 Hz 1.7 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV - FURRYe38Jan 21, 2022Guru - Experienced User
Power levels are all over the place.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Also seeing corrected code words which should all zeros. The ISP needs to check your service line.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
