NetRags's avatar
NetRags
Tutor
Jun 23, 2017
Slow WAN speed wireless - Cable Gateways
Hi Team,
I searched for KB article on 'How to troubleshoot slow WAN speed - wired/wireless' in your support portal. But I couldn't figure it out. However below is the set of troubleshoot which I had performed.
Model: C6300
FV: Up to date with ISP
Laptop: Win7 & Win8 - Both the Laptop's WLAN supports AC Wi-Fi standard
Smartphone: iPhone6s & iPhone7 with latest iOS
ISP: Xfinity
Subscribed Internet Speed: D/L - 200Mbps & U/L: ~ 60Mbps
Issue not just happening during the peak hours. Through out the day, wireless internet speed is too low.
Microwave Oven is turned OFF (too far away from the Gateway)
No interfering devices nearby
Ensured all the devices are disconected from the Gateway network while doing speed test wireless with Gateway
When Laptop hardwired to the Gateway using CAT6 cable this is what the internet speed - 180Mbps/55Mbps
Disconnected ethernet connection from Laptop
Already removed preferred wireless networks
Using Gateway preset wireless settings
No other configurations done on the gateway except provisioning it with ISP (Xfinity)
When performed speed test wireless again it flickering between 30 - 40Mbps
Not just with 2.4GHz also with 5GHz
I don't think so it is nothing to do with device DS / US Power / SNR / Channel Lock Status
Changing the Gateway wireless channel / Mode doesn't resolved the issue. I changed the channel using the option 'Wireless Channel' in the GUI. Also tested the interferences using NETGEAR Wi-Fi Analytics App.
Note: Did reset, power cycle, reprovisiong the device with ISP, ensure WLAN adapter is updated with latest driver, tested with multiple locations and still the issue is same.
This slow wireless speed issue isn't happening only with C6300 and also with other NETGEAR cable gateway's.
Moreover there is no valid or the MOST appropriate KB article available for speed issues (Wired/Wireless)
How to fix these issues?
When will the appropriate KB articles posted for speed issues?
If possible, check the number of customers reporting about the slow WAN speed wireless issues to you guys. Specficailly with NETGEAR Cable Gateways.
Regards,,
NetRags
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Netrags
    I would test the network by disconnecting every device from the wifi and then connect your newest device and test the speed then add a device 1 by one and see if one of you devices are causing the slow down.
    DarrenM
