JohnDrew98
Feb 22, 2023Tutor
Slow Wi-Fi speed but have great speed when hardwareed.
I have a C6250 purchase 1-1-2023. I have 300 mb when hardwired to my pc. On WiFi I only have 0-49mb. My Feit lights say Network Error. Please Check. Obviously it's with the C6250. The only item ...
JohnDrew98
Feb 22, 2023Tutor
Yes they are a Google Mesh system.
What is strange is Netgear92-5G does not appear on my computer but does on my IPHONE....The Google ID is num 1.
Feb 22, 2023Guru - Experienced User
Not really strange if your computer is a single band device.
You have to have a dual band device to see the 5ghz.
what wireless card is in the pc?
Also, why are you using the google mesh and the netgear?
You can just use the google mesh by putting the netgear in modem only mode and then you're not in a double nat.
- JohnDrew98Feb 22, 2023Tutor
How do I change to Modem mode only? I tried the 2G and 5G on my Iphone settings and tried the Speedtest.net and get "Test Failed". I am using Optimum Pluse as server. They came out and said I am getting 300
- michaelkenwardFeb 22, 2023Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Cable the Modem Router to a Router and Use Bridge Mode.
