ddflink
Apr 27, 2020Aspirant
Slow Wifi - C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router
I have a C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router with Comcast service up to 100 mbps. the modem is in the basement connected to a luxul xp-1500 extender (into the basement ceiling) and two...
Apr 28, 2020Guru - Experienced User
What speeds to you get with just the wifi on the C series modem only? Turn off all other extenders.
- ddflinkMay 05, 2020AspirantCurrently i'm getting 50 mbps from 2.4 and 100 from 5g and similar from the extenders but it's very spoty
- FURRYe38May 05, 2020Guru - Experienced User
Might go with NG extenders to see if those work better. EX7000 would be a good match...
ALso distance with extenders is important. 30 feet to start in between the modem and extenders is a good starting point. Depending upon building materials. Concrete and steel will impact wifi travel.
