ddflink
Apr 27, 2020Aspirant
Slow Wifi - C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router
I have a C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router with Comcast service up to 100 mbps. the modem is in the basement connected to a luxul xp-1500 extender (into the basement ceiling) and two...
Apr 28, 2020Guru - Experienced User
What speeds to you get with just the wifi on the C series modem only? Turn off all other extenders.
ddflink
May 05, 2020Aspirant
Currently i'm getting 50 mbps from 2.4 and 100 from 5g and similar from the extenders but it's very spoty
- FURRYe38May 05, 2020Guru - Experienced User
Might go with NG extenders to see if those work better. EX7000 would be a good match...
ALso distance with extenders is important. 30 feet to start in between the modem and extenders is a good starting point. Depending upon building materials. Concrete and steel will impact wifi travel.
