MarceloLuca
Oct 18, 2017Aspirant
Slow WiFi C6300 after firmware update
For the last 2 weeks my Wifi has been very very slow on downloads. I have TWC supposedly at 60MBPs but I am having less tehm 10 on speed tests and felling really slow. I did a test connecting via ...
DarrenM
Oct 20, 2017Sr. NETGEAR Moderator
Do you have any really old wifi devices connected to the wireless? Have you tried to connect only the laptop and run a test?
DarrenM
MarceloLuca
Oct 20, 2017Aspirant
My oldest device is my Iphone6
Todays TWC technician was here, and tested cable, daid everything looks ok, from their side.
When I perform the speed test, it shows up to 30-50Mbps, but the issue now is that it takes a few seconds to get this speed. And the worse, navigation on wifi devices steel very slow despite any speed showed on tests
- DarrenMOct 20, 2017Sr. NETGEAR Moderator
I suggest contacting our support could be a issues with the hardware.
http://www.netgear.com/support/contact.aspx
DarrenM
