Bakersanchez
Apr 30, 2020Follower
Slow wifi connection
I called my internet provider and they said they are showing over 800 mbps going to my router, but my wifi isn't getting a good speed. Less than 10 mbps. Anyone have any suggestions?
May 04, 2020Guru - Experienced User
What devices are you speed testing with?
Are wired PC speed test good?
Most current wifi devices along with the wifi on the modem will probably max out at around 300-400Mpbs depending upon confiuration, settings and device support.
