jrcarte78
Oct 13, 2020Aspirant
Slow WIFI Speeds - Cox Gigablast
Hello, I have C7800 / Cox ISP / Gigablast plan (rated for 940 MBPS). I routinely get no more than 70 - 80 MBPS on the 2.4 channel and no more than 100 - 110 MBPS on the 5G. Cox has stated tha...
Oct 13, 2020Guru - Experienced User
What wireless device are you using?
Most 5Ghz AC mode devices max out at 400-500Mpbs depending on designe and support of the device. You'll never see anything near 800-900Mpbs on wireless 5Ghz AC. Ethernet you should.
