K33
Nov 16, 2020Aspirant
Slow wifi speeds on 3700-NAS100
The modem is a hand-me-down and over a year old and so I probably can't get Netgear's support. It is on the latest firmware from Comcast. There are so many posts with the same problem but I coul...
K33
I don't have a way to test pc to modem via LAN cable. It's too far. With the laptop connected via LAN, however, it is 300 Mbps.
Only tested via Laptop and PC. No mobile devices (phone, tablet, etc) tested.
Nov 16, 2020Guru - Experienced User
Wireless device speeds vary depending upon design, support and configuration.
- K33Nov 17, 2020Aspirant
I have the configuration set to "up to 300 Mbps" but I'm only getting 30 Mbps on my pc and only 7-10 on my laptop.
- FURRYe38Nov 17, 2020Guru - Experienced User
The up to 300Mbps is a connection rate between the modem and the wireless device, not actial bandwidth speed thrughput. Two different things.
Right but laptop was getting 300 Mbps via wired connection and therefore should still get 300 Mbps via wireless, should it not?
