Troubled67
Aug 30, 2017Aspirant
Slow Wifi speeds
I have a link speed of 351 mbps from my IP, but I am only receiving a throughput speed of 2.4 mbps through my wireless router. I have reset the Router, tried the 30-30-30 method, changed channels, an...
Troubled67
Aug 31, 2017Aspirant
With a wired connection, I receive 351 mbps through my Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router. When I try to connect to my desktop wirelessly, I can only get 2.4 mbps. I also have a Roku connected to a bedroom tv, and the picture is terribly pixelated. I assume this is because the router can't stream fast enough.
michaelkenward
Aug 31, 2017Guru - Experienced User
Have you tried changing the wifi channel? If you are in a noisy wireless environment, you may see interference from neighbours.
A wired connection to the bedroom TV, perhaps with powerline plugs, may be better than wifi.
Is the Roku wired to the router? If not, that too might be better wired.
