bmelroe
Apr 14, 2020Follower
Slow WiFi with a C7000v2 cable modem
I have a C700v2 cable modem. My desk top computer is hooked to the modem via a network cable to receive the internet signal. I am useing Comcast as a provider. I am receiving high 70's mbps for do...
Apr 15, 2020Guru - Experienced User
Depends on what wifi devices your using to speedtest with and configuration of the modems wifi and your environment.
Most newer wifi devices should test out well over 100Mbps. Most currenty wifi phones or pads may max out at around 400-500Mbps depending upon design and what NG designes for the specs of the modem.
