Dandoom919
Jul 04, 2016Aspirant
slow wifi
I just bought the C6300 Modem Router, Time Warner had a hard time getting the internet to work but finally got it going, I pay for 50Mbps, the first day the wifi was super fast I check the speed it s...
SeesforMiles
Jul 05, 2016Aspirant
I'm on my second unit, having the same issue. I'm paying Comcast for 250 Mbps. I get all that speed if I am hard wired to the modem router. Wirelessly, I'm getting anywhere ferom 1.4 to 41 Mbps. I've been through Netgear support, and don't have much confidence that they know what they're doing. Does anyone here have experience with this problem? More importantly, does anyone have a way to overcome it?
- Dandoom919Jul 06, 2016Aspirant
OK I found out how to fix my issue, I'm sending the C6300 back where i bought it, what junk, I'm replaceing it with ARRIS SURFboard SBG6900AC hoping I have better luck. Thanks for the reply
- DarrenMJul 11, 2016Sr. NETGEAR Moderator
Hello Seesformiles
Have you tried to adjust the wireless channels on the C6300 you can get a app on android called Netgear wifi Analytics that will help find the best channel for your area and there are other free apps on apple that can do this as well.
DarrenM
