cybernigel
Dec 11, 2017Aspirant
Slow Wireless / Fast Wired
For my AC1600 (model C6250) speed test with ethernet cable is 120Mbps down, but with 2.4Ghz wireless from 5 feet away it is only 20Mbps. Any suggestions?
cybernigel
Dec 17, 2017Aspirant
Hi David,
I appreciate the reply. What specific adjustments to the 2.4Ghz channel are you suggesting?
Thank you
DarrenM
Dec 18, 2017Sr. NETGEAR Moderator
This Kb may help you with this just apply the same method it outlines to the 2.4ghz network.
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
- cybernigelDec 18, 2017Aspirant
Hi Darren,
I appreciate the reply and helpful KB article. I will try using a channel analyzer, but I did some brute force troubleshooting last night and tried each of the available 11 channels and ran speedtest.net against them. On the best channel I was still only getting ~30Mbps down while with a wired connection I'm well over 100Mbps down. I performed these tests about 5 feet away from the router and the R6250 does not have any adjustable attennas. Any other suggestions?
Thanks a lot
