Regman
Feb 17, 2025Tutor
Smart Oil Gauge 2.4 connection issue
My smart oil gauge keeps dropping off my network. It's only 2.4 I can manually connect but it immediately drops off. I tried new batteries, moving it very close to my Nighthawk AX8, switching channe...
Feb 18, 2025Guru - Experienced User
got the old apple or a different router sitting around?
Might try sticking them in access point mode and just running the 2.4ghz on it. And just connect the oil gauge to that.
Reading the reviews on it, there was a lot of hit/miss's for people. Quite a few reporting connectivity issues. Makes me curious if its something inherent to the gauge connecting to the AX spec.
Regman
Feb 25, 2025Tutor
Thank you, simple solution. Your suggestions worked great. Been receiving gauge readings for the last five days. Thanks again
