mruvrayz
Mar 08, 2018Tutor
so i just bought the netgear cm1000 but its network name isnt showing up on my wifi search list
antinode
Mar 08, 2018Guru
> [...] i just bought the netgear cm1000 but its network name isnt
Perhaps that's because the CM1000 is a modem, not a
modem+wireless-router, and, as such, it has no wireless-network
capability.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the Product Data Sheet or the User Manual.
Read.
Then, start looking for a wireless router to use with your CM1000, or
a combined modem+router to replace it.
General advice: Don't begin a conversation with "so". It requires an
antecedent.
- mruvrayzMar 08, 2018Tutor
thank you for the information i now have another qestion why doesnt my ps4 connet the modem through ethernet cable but my laptop does without a problem
- antinodeMar 08, 2018Guru
> [...] why doesnt my ps4 connet the modem through ethernet cable but my
I don't know. Are you trying to connect them at the same time? How?
Even if you connect only one device to the modem, you may need to
restart the modem (and then the device) when you change the device which
is connected to the modem.
Connecting a router to the modem would make it easier to use multiple
devices. The modem would see only the router, not a bunch of different
devices. A router can deal better with multiple client devices.- mruvrayzMar 08, 2018Tutor
so when i connect my laptop(no othe device is connected at this time) to the modem majic happens but when i connect the ps4(no other divce is connected at this time as well) to the mode there is no majic
