Ltwarren
Mar 31, 2020Aspirant
solid amber ethernet light on cm1000
as soon as I plug the modem in all lights flash and then turn off leaving the ethernet light solid amber. I've tried to push the factory reset button but it does nothing. Ive held it down for as long...
Apr 01, 2020Guru - Experienced User
ALL the lights are off other than ethernet? even the power light is off?
did you just buy this?
did you get it activated by your isp?
Who is your isp?
The ethernet amber means that an ethernet connection is detected at 10/100mbps speeds.
Ltwarren
Apr 01, 2020Aspirant
Yes as soon as I power on the modem all lights flash and then go off leaving the Ethernet light on.
I did just purchase it used.
I have Xfinity but I can’t even get it to do anything in order to register it.
