Ltwarren
Mar 31, 2020Aspirant
solid amber ethernet light on cm1000
as soon as I plug the modem in all lights flash and then turn off leaving the ethernet light solid amber. I've tried to push the factory reset button but it does nothing. Ive held it down for as long...
Apr 01, 2020Guru - Experienced User
Where you have it hooked up, did it work prior?
Preferablly, hook up the modem directly where the coax enters the home.
Mabye there's an issue with the auto activation or maybe the prior owner had it provisioned with an ISP that doesn't have auto-activation.
You might need to call into xfinity and see if they can provision the mac address.
hardwired into the modem, can you ping it?
When you push and hold reset, do the lights change?
Ltwarren
Apr 01, 2020Aspirant
I’m hooking it up in the same place I had my cm700 hooked up at. The previous modem worked fine.
Even the reset button does not change a thing regardless of how long I press it.
It’s fairly unresponsive....
