harshildonga
Aug 27, 2020Aspirant
Solid Amber upstream light
I am having solid amber upstream light in my modem Netgear C6300 and i believe because of that i am getting rediculosly slow speed for my internet. I am attaching my log detail here. any help wo...
harshildonga
Yes, I have performed factory reset but its not working either
Aug 27, 2020Guru - Experienced User
IF all the other suggestions have been checked, you could try a different modem to see if the problem remains for goes away. If it goes away with a new modem, then the C series modem could be marked as the culprit, if the problem continues with a new modem then there is a ISP service line issue that the ISP needs to resolve.
