harshildonga
Aug 27, 2020Aspirant
Solid Amber upstream light
I am having solid amber upstream light in my modem Netgear C6300 and i believe because of that i am getting rediculosly slow speed for my internet. I am attaching my log detail here. any help wo...
Aug 27, 2020Guru - Experienced User
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Has a factory reset been performed on the modem?
Spilette
Dec 08, 2020Aspirant
Same for me, I did factory reset, shut this off..
still nothing..signal look like this
- FURRYe38Dec 08, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Spilette wrote:Same for me, I did factory reset, shut this off..
