rgrimjr41
Nov 01, 2024Aspirant
Sometimes rebooting the CM2050V causes downstream light to blink.
My signal levels are good. The cable company has been out three times in the last two weeks. They say they cannot find a problem. I pay for Gigabit extra 1.2g/40mbps. Signal levels are all good abd op...
Nov 01, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status...
rgrimjr41
Cable Connection
Cancel Apply
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
0
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 579000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 29 579000000 Hz 1.4 dBmV 41.9 dB 6 0
2 Locked QAM256 1 393000000 Hz -0.8 dBmV 42.2 dB 0 0
3 Locked QAM256 2 399000000 Hz -1.0 dBmV 42.0 dB 1 0
4 Locked QAM256 3 405000000 Hz -1.0 dBmV 41.9 dB 0 0
5 Locked QAM256 4 411000000 Hz -1.0 dBmV 41.9 dB 1 0
6 Locked QAM256 5 417000000 Hz -0.8 dBmV 42.0 dB 2 0
7 Locked QAM256 6 423000000 Hz -0.6 dBmV 41.9 dB 3 0
8 Locked QAM256 7 429000000 Hz -0.7 dBmV 41.8 dB 2 0
9 Locked QAM256 8 435000000 Hz -0.7 dBmV 41.7 dB 5 0
10 Locked QAM256 9 453000000 Hz -0.2 dBmV 41.8 dB 4 0
11 Locked QAM256 10 459000000 Hz -0.1 dBmV 41.8 dB 3 0
12 Locked QAM256 11 465000000 Hz 0.0 dBmV 41.7 dB 2 0
13 Locked QAM256 12 471000000 Hz 0.1 dBmV 41.7 dB 5 0
14 Locked QAM256 13 477000000 Hz 0.2 dBmV 41.7 dB 3 0
15 Locked QAM256 14 483000000 Hz 0.3 dBmV 41.7 dB 6 0
16 Locked QAM256 15 489000000 Hz 0.4 dBmV 41.7 dB 3 0
17 Locked QAM256 16 495000000 Hz 0.4 dBmV 41.6 dB 10 0
18 Locked QAM256 17 507000000 Hz 0.5 dBmV 41.7 dB 2 0
19 Locked QAM256 18 513000000 Hz 0.7 dBmV 41.8 dB 2 0
20 Locked QAM256 19 519000000 Hz 0.6 dBmV 41.8 dB 6 0
21 Locked QAM256 20 525000000 Hz 0.6 dBmV 41.7 dB 7 0
22 Locked QAM256 21 531000000 Hz 0.5 dBmV 41.6 dB 7 0
23 Locked QAM256 22 537000000 Hz 0.6 dBmV 41.6 dB 8 0
24 Locked QAM256 23 543000000 Hz 0.7 dBmV 41.8 dB 13 31
25 Locked QAM256 24 549000000 Hz 0.2 dBmV 41.5 dB 25 0
26 Locked QAM256 25 555000000 Hz 0.1 dBmV 41.4 dB 20 0
27 Locked QAM256 26 561000000 Hz 0.8 dBmV 41.7 dB 14 0
28 Locked QAM256 27 567000000 Hz 1.2 dBmV 41.9 dB 8 0
29 Locked QAM256 28 573000000 Hz 1.2 dBmV 41.8 dB 13 0
30 Locked QAM256 30 585000000 Hz 1.5 dBmV 42.0 dB 9 0
31 Locked QAM256 31 591000000 Hz 1.6 dBmV 41.3 dB 12 0
32 Locked QAM256 32 597000000 Hz 1.8 dBmV 41.9 dB 4 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 10 5120 16400000 Hz 46.5 dBmV
2 Locked ATDMA 11 5120 22800000 Hz 46.5 dBmV
3 Locked ATDMA 12 5120 29200000 Hz 46.0 dBmV
4 Locked ATDMA 13 5120 35600000 Hz 46.5 dBmV
5 Locked ATDMA 14 2560 40400000 Hz 46.0 dBmV
6 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock Status Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 ,3 159 678000000 Hz 2.2 dBmV 41.7 dB 1126 ~ 2969 207064343 34828393 0
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
Current System Time:Fri Nov 01 10:32:25 2024
System Up Time:01:28:12
Help CenterShow/Hide Help Center
Cancel Apply
Starting Frequency
0
Startup Procedure
Codewords
- FURRYe38Nov 01, 2024Guru - Experienced User
Ok,
Power looks good.
Seeing some Correctables and un-correctables, not bad however should be mostly zeros.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the brand and model of the host wifi router connected to the modem?- rgrimjr41Nov 01, 2024AspirantI am using the glinet mt6000 Flint 2. Another thing is my download speeds are all over the place. I subscribe to 1200mbps down and I am lucky to hit 600mbps down most of the time. Comcast has been out three times. They keep saying they cannot find any problems. I have two lines running to my modem. Both are brand new. I am using high quality rg6 quad shield cable. The other is Comcast RG6 cable shieldx trishield I think it is called. There are no splitters or anything. Just a straight shot to the ground block and then to the tap on the pole.
I don't think the Cm2050v is approved for there next gen speed tier:
It's on there recommended list however that's on there lower speed tier only I believe. Will be up to them to work with NG to make the 2050v supported on there higher speed tier.
The ISP needs to look at the event logs and resolve them.
