mark1210
Jun 16, 2020Tutor
Spectrum - Partial Service Dispalyed in GUI along with OFDMA Upload Enabled
vkdelta and Others.... I'm getting conflicting information from Spectrum and wanted to make sense of all this if I could with regards to my CM1200 modem: 1) That the "Partial Service" me...
Jun 16, 2020Guru - Experienced User
You might try a CM1000 or CM1100 to see if the same thing happens if you don't get any responce from NG moderators.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
