Ferroid
Apr 22, 2019Tutor
Spectrum compatible Cable Modem
I'm currently shopping for a new cable modem for my Spectrum service and wanted to get some input on two different models of Netgear modems. I don't have voice service and don't need a router so I've...
Apr 22, 2019Guru - Experienced User
Any of the CM models will work if your ISP supports them.
You need a router behind the CM modems as they don't support router or wifi. So if you have a router already, then either one of thes models will connect up to the external router.
The CM1200 is mostly meant for businesses, not home. Depends on what ISPs will supprot for it:
https://www.netgear.com/support/product/cm1200.aspx
The 1100 is a good modem FYI.
