wywrite
Dec 29, 2021Tutor
Spectrum.net 403 Forbidden error
I have an AC1900 C7000v2 Modem/Router. I use Spectrum internet. For some reason, any time I try to connect to Spectrum.net (but not Spectrum.com or other websites), I get a 403 forbidden error. I con...
wywrite
Dec 29, 2021Tutor
Just tried it -- same result.
plemans wrote:Have you tried changing the DNS provider?
you can try google at 8.8.8.8 or 8.8.4.4or cloudfare at 1.1.1.1
Dec 29, 2021Guru - Experienced User
does it work on different devices? or are all devices blocked?
- wywriteDec 29, 2021TutorBlocked on multiple different devices (including phone) and browsers. If I turn WiFi off on phone, I can open the site, so definitely connected to the modem/router in some way.
- plemansDec 29, 2021Guru - Experienced User
Can you ping the site from a command prompt?
- nielsvdsDec 29, 2021Luminary
Are you using a VPN on your devices where you can change the country? If so that can cause access to some website that are using GEO blocking .Try to disable your VPN. In some browser there is also a VPN build in.
