wywrite
Dec 29, 2021Tutor
Spectrum.net 403 Forbidden error
I have an AC1900 C7000v2 Modem/Router. I use Spectrum internet. For some reason, any time I try to connect to Spectrum.net (but not Spectrum.com or other websites), I get a 403 forbidden error. I con...
wywrite
Dec 30, 2021Tutor
Ping request timed out.
Also, to the VPN question -- not using a VPN
Dec 30, 2021Guru - Experienced User
Have you ever tried a simple factory reset/reinstall (not from a backup)?
- nielsvdsDec 31, 2021Luminary
Do you have configured the option to block certain websites based on keywords? Page 34 - Page 36 of the user manual.
- plemansJan 03, 2022Guru - Experienced User
You can always make a backup configuration.
Then after you reset, test the connection. If it works, reinstall your backup and test it again to see if its something in the backup.
