solarissf
Oct 08, 2020Aspirant
speed directly from modem half what it should be. cm1150v
I currently pay for 600mb download speed and when I run speed tests from a computer hardwired directly into modem I am only getting around 250-275mb on xfinity speedtest. I called xfinity and they t...
solarissf
ok, I'll try that and come back here with results.
satvik
Hi
I am getting similar issues but over wifi. Have called support for a month but nothing is being done by netgear to replace the faulty modem router. They keep asking to change settings but nothing helps. They also closed the case to not provide support.
