Johnkov67's avatar
Johnkov67
Speed issues C3700 - 100NAS with Xfinity and a 400Mbps service plan
I just upgraded my plan through xfinity from 150Mbps to 400Mbps. My previous speed tests had results of 4.8 Down and 6.2 Up. Once they did their thing and my modem/router reset, I re-tested and got the results posted in the screenshot. Is there something I need to do in the settings of the router to increase the speed or is it something on the ISP's end?
  • FURRYe38's avatar
    Is this result with a wired PC or wireless device. Besure you test with a wired PC connected to the C series modem first.
    Try different devices and a different PC if possible.
    • Johnkov67's avatar
      Johnkov67
      I am on a wired PC. with about 15 ft of Cat5 between me and the router.
      • FURRYe38's avatar
        Try with a CAT6 cable. Different PC if you have one.
        Ensure your pc doesn't have any background running apps running while speed testing.
    • plemans's avatar
      FURRYe38 wrote:
      The modem is a 8x4 modem.
      Yep, and its not rated >150mbps. Theoretically it allows up to 340 mbps but comcast doesn't certify it for that. I'm just saying that they require at least a 16x4 for >150mbps.
    • plemans's avatar
      I didn't mean to imply the c3700 was 16x4. I was just going over what comcast requires for certain service levels. Again, with that said, that device should still be getting better speeds than its reporting.
      • FURRYe38's avatar
        I presumed that. I was just posting the channel specs.
