AndySS
Mar 07, 2019Tutor
Speed issues with C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router
hello everyone
need help with
C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router. I have a 3400SQFT house and am facing range issues on the first floor. I got this router since it said that it w...
Ramon77
Mar 08, 2019Tutor
I have the exact problem you're having and I'm sorry to say I recieved no help! I have the exact model you have and it's nothing you're doing wrong but it's the latest firmwire that's causing slow internet speed. I've been trying to figure out how to revert back to a previous firmwire but with no luck. The firmwire is causing all of this!
AndySS
Mar 08, 2019Tutor
Thank you..am not very pro when it comes to network—what does this firmware thing have to do? And can that be fixed?
- ZeroC00lMar 10, 2019Luminary
Problem is these router like my c7000 you cannot update the firmware, Your ISP has to. I to get speed issues with it.
I wish Netgear would test it or push a new one for our ISP's. This has been going on for awhile now.
- AndySSMar 10, 2019TutorThank you..will a network extender help? I was reading about this nethear wifi extender, not Orbi
- ZeroC00lMar 12, 2019LuminaryI don't think so no. If the wifi is flakey because of the firmware, it won't help.
Only time it will do you good when your getting good wifi speeds to begin with.
If anything go mesh routing. That'll be worth it if you got the money to invest into something like that.
