dag_dg
Jul 03, 2019Follower
Speed test on CM600
If anybody in the community has a CM600 and a connection with speeds higher than 600 Mbps can you please post speed test results? I'm confident this modem can handle speeds approaching it's rated lim...
Jul 03, 2019Guru - Experienced User
Which provider do you use?
The cm600 is rated "up to 960mbps" but each provider has a certain speed they'll guarantee with it.
Comcast enables 24x8 modems (most vendors 24x8 units are the same) for mostly 250/300 Mbps extreme service and 400 Mbps Extreme service. So if you're hitting 600mbps, I'd think you're doing quite well with the CM600. Most require docsis 3.1 to hit gigabit speeds.
