Airwave
Oct 28, 2015Aspirant
SpeedHelp, Troubleshooting
I just installed a new Netgear C6300 trying to get my internet speed up to the 100Mbps I am paying for and I am still only getting 58.20Mbps, what can I do to fix this please?
vkdelta
Oct 28, 2015NETGEAR Employee Retired
1. how are you testing speeds?
2. Who is your ISP?
3. What Firmware is your running?
4. What package did you subscribed for?
- AirwaveOct 29, 2015Aspirant
I have Suddenlink Communications and I have tested the speeds using their speed tester and with Speakeasy speed tester and Speedtest.net.
I am using what ever the computer set up the modem/router with, their is no firmware download for this modem at Netgear so I can't even download a driver specifically for this unit. I am signed up for 100 Mbps. My motherboard is showing a NVIDIA nForce 10/100/1000 Mbps Ethernet connection with a driver of nvm60x32.sys version 6.02.00.1126, with a date of 6/21/2006, NVIDIA is the provider. I checked and can not find a newer version.
My test speeds at all three locations are showing a download speed of 58.20 and an upload speed of 10.25.
- vkdeltaOct 29, 2015NETGEAR Employee Retired
can you please provide connection page and event logs GUI screenshots?
I believe it is mostly a provisioning issue where ISP has sent the config files with lower speed-tier. Is it possible for you to call and double check with suddenlink?
