xSendNukes
Sep 19, 2020Guide
Splitters and signal levels
https://ibb.co/0FXFvps https://ibb.co/T88nBkB Recommended downstream power levels are -7 dbmv to +7 dbmv Recommended upstream power levels are 35 dbmv to 49 dbmv (Modem manufacturer, Arris, rec...
Sep 19, 2020Guru - Experienced User
Are you having issues?
Either one looks decent. You don't have errors.
If you're loosing speeds/packets/or having drops, then I'd have the isp check the line but otherwise it looks fine.
