Piper43078
Sep 26, 2022Aspirant
Splitting/ switching a Modem signal
Can a modem signal be ‘split’ and then sent to two different/ separate routers?? If so what netgear product can achieve this?
Piper43078
Sep 27, 2022Aspirant
Thanks… not splitting the coaxial, trying to split the signal coming out of the Optimum modem and then to two separate routers.
I think you answered it… only 1 IPS per modem/ account….
Thanks
Thanks
Sep 27, 2022Guru - Experienced User
Might ask the ISP if they support having more than 1 WAN IP address to one line. Some ISPs may support that.
