Keninboston
Jan 04, 2024Aspirant
Sporadic router freeze on CAX80 - only when using WiFi
My Problem: Sporadic router freeze on CAX80 - only when using WiFi Am looking for help troubleshooting assistance. CAX80, hardware Version: 1.01, Firmware Version: v1.02.08. Connected to Xfinit...
Jan 04, 2024Guru - Experienced User
Your behind on FW:
What wifi channels are you using?
What wifi devices do you all have connected?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- KeninbostonJan 05, 2024Aspirant
Thanks for the reply! Let me know if there is something I left out. My info below:
Firmware
I realized I put in the cable firmware and not the router firmware. I didn't realize that there were separate firmware setups for cable and router, I am current on router updates, here they are for reference:
Firmware Version V2.1.5.2 Cable Firmware Version V1.02.08 What wifi channels are you using?
For 2.4 GHz, channel is set to auto and currently 9. 5GHz is set to 48. I've tried switching them around with no change in behavior.
iPhone, 2 iPads, Macbook, LG SmartTV.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...Cable ConnectionCancel ApplyCable Diagnostic Status: Good Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info. Internet Access: Downstream Status: Upstream Status: Refresh Save Cable Diagnostic Info Advanced Information Frequency Start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Time Priority Description Fri Jan 5 14:39:14 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 14:37:24 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 14:35:30 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 14:29:50 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 13:40:00 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 13:36:27 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 11:10:07 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 11:06:24 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 09:54:29 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 09:52:48 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 07:48:06 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Fri Jan 5 07:43:40 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 22:30:11 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 22:28:37 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 21:55:55 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 21:49:14 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 20:41:29 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 20:35:06 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 20:33:21 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 20:29:57 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 18:07:37 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 18:05:43 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 16:09:40 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 16:05:16 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 15:48:34 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 15:42:08 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 15:13:35 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 15:13:02 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 12:23:59 2024 Critical (3) UCD invalid or channel unusable;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 12:23:57 2024 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 12:23:31 2024 Notice (6) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:50 1970 Notice (6) Honoring MDD; IP provisioning mode = IPv6 Thu Jan 1 00:00:44 1970 Critical (3) UCD invalid or channel unusable;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 4 12:13:34 2024 Critical (3) UCD invalid or channel unusable;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:46 1970 Critical (3) UCD invalid or channel unusable;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:44 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Jan 2 20:23:51 2024 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 20 23:11:58 2023 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1; Sat Dec 16 10:13:54 2023 Critical (3) UCD invalid or channel unusable;CM-MAC=80:cc:9c:dd:a5:b0;CMTS-MAC=00:90:f0:44:00:00;CM-QOS=1.1;CM-VER=3.1;
