DrFrankenstein
Aug 10, 2018Aspirant
Sporadic Success Opening SSL VPN Connection through C7000-100NAS Gateway/Router
I have had the same ISP (Comcast Xfinity) and gateway/router (C7000-100NAS) set-up at home for about two years and have been very happy with general performance.
From my laptop I access an SSL...
DrFrankenstein
Aug 13, 2018Aspirant
Found that I can connect to work SSL VPN if I temporarily disable the router firewall. Then I can re-eanble firewall and stay connected.
I'm guessing that the firewall does not like me trying to connect to the VPN. However, since this is a recent development I am thinking it might have something to do with a Firmware update?
- vkdeltaAug 13, 2018NETGEAR Employee Retired
Hi,
Can you please PM me working and not working wireshark captures? We would like to see them.
