billgiannelli's avatar
Jan 14, 2020
standing CM1200 on side or back
the CM1200 is too tall to fit on my shelf. might there be a stand to have modem on its side or back?
thanks
Bill
  • plemans's avatar
    I don't know of any aftermarket or stock stands for the cm1000, cm1100, or cm1200.
    I do know they're designed to dissipate as much heat as possible. You could potentially try laying it on its side but I'd make sure it has adequate airflow to dissipate that heat.
  • FURRYe38's avatar
    If you lay it down, I would put a small fan on it to keep it cool.
