mpeterson0418
Feb 09, 2022Tutor
Static routing on CAX80
Have a question/concern for the Netgear community - although I think this might be more of a feature inquiry than anything Recently purchased a Nighthawk CAX80 modem, and replaced my Comcast DPC3...
Feb 12, 2022Guru - Experienced User
Does any of these article help configure and check static routing>
mpeterson0418
Feb 13, 2022Tutor
The problem is that there is no option for “static routes” under the advanced section. I’m convinced that it’s just not an available option on this modem
- FURRYe38Feb 13, 2022Guru - Experienced User
You are correct.
- olympos1625Feb 16, 2022NETGEAR Employee Retired
Hi mpeterson0418,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching out. We are communicating with the appropriate department about this feature. We will get back to you soon.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- mpeterson0418Feb 22, 2022Tutor
Hi Oliver,
That would be great if you could get some further validation on that - or if possible even work to implement this feature in a future firmware release. If you're paying $400+ for a device, I'd think anyone would want some of those fun features to play around with
I also only suggest this - because I do know that some of your other netgear router models provide this functionality based on your KB articles = https://kb.netgear.com/24322/How-do-I-set-or-edit-static-routes-on-a-NETGEAR-router
- olympos1625Feb 26, 2022NETGEAR Employee Retired
Hi mpeterson0418,
Engineering confirmed that Static Routes are not supported on CAX80. The UM for CAX80 has no mention of Static Routes at all. We already asked our Marketing team to update the KB articles. We are sorry for the inconvenience.
Oliver
Community Team
