jlogan85
May 04, 2016Aspirant
Steady Red Light on Power - c3000
Hello Community, I have a refurbished C3000 modem that was purchased August 2015. It has been working fine, no issues at all until tonight when the reouter lights all went off and the power light is...
VE6CGX
May 04, 2016Master
I think router is sick. Looks like part of the router circuit lost power.
DarrenM
May 05, 2016Sr. NETGEAR Moderator
Hello jlogan85
Yea if the modem is showing the power light as solid red then there is sometype of hardware failure that is happened not much you can do but try to factory reset the device to see if it comes back on. If you are still under Hardware warranty I would contact Netgear support.
DarrenM
