jlogan85
May 04, 2016Aspirant
Steady Red Light on Power - c3000
Hello Community, I have a refurbished C3000 modem that was purchased August 2015. It has been working fine, no issues at all until tonight when the reouter lights all went off and the power light is...
jlogan85
May 05, 2016Aspirant
I assume since i bought the modem as Refurbished from Groupon Aug 2015 that i am no longer under any warranty. Is my assumption correct?
- DarrenMMay 05, 2016Sr. NETGEAR Moderator
Hello jlogan85
you can check by registering it at
http://www.netgear.com/support/contact.aspx?cid=gwmng
DarrenM
