laceymike's avatar
laceymike
Still can't get in my C7100V Modem Router
I'm thinking I'm not in my router. I switched to firefox as a browser and entered the IP address in the URL field and the Netgear Genie popped up. But the "Advanced" tab is blackened out and I can't ...
  • plemans's avatar
    Oct 21, 2019
    I'd try to access it with either chrome or edge (can't believe I just said try edge). Chrome had issues for a bit and I've read of other browsers that occassionally have issues.
    If that doesn't work, I'd try a factory reset first and then if that doesn't work, contact your isp and see if they can see the C7100v. Potentially the can resend the firmware on it to you.
