BHerm24
Jun 16, 2020Aspirant
Still randomly losing internet connection
I attached a snip of cable connection setting for my modem. My internet continues to randomly stop working the steps I have taken are. 1. Called my provider (Suddenlink) and they scheduled a tech to...
Jun 16, 2020Guru - Experienced User
Well you have a ton of errors in your line.
You're starting to run into a rock/hard place with suddenlink. They've checked the line but there's still issues.
so its either truly a line issue or you do have a modem issue. I'd be voting on the line issue but suddenlink starts to get bucky when they've already sent out techs 2x.
If they do get problematic, I've rented a modem from them before and then they can't blame it on the 3rd party device. Once they get it fixed, then swap back to yours and return their modem.
- BHerm24Jun 16, 2020Aspirant
This is a brand new modem out of box about a month ago. Also when first tech came out I took a screenshot and only errors I was getting on downstream was on channel 11 everything else was 0.
This did only start once I had the new modem though too. So maybe I just need to send it back?
- plemansJun 16, 2020Guru - Experienced User
it could be the modem, it could be when the last tech was checking the line, they actually loosened something. Wouldn't be the first time
