BHerm24
Jun 16, 2020Aspirant
Still randomly losing internet connection
I attached a snip of cable connection setting for my modem. My internet continues to randomly stop working the steps I have taken are. 1. Called my provider (Suddenlink) and they scheduled a tech to...
Jun 16, 2020Guru - Experienced User
Well you have a ton of errors in your line.
You're starting to run into a rock/hard place with suddenlink. They've checked the line but there's still issues.
so its either truly a line issue or you do have a modem issue. I'd be voting on the line issue but suddenlink starts to get bucky when they've already sent out techs 2x.
If they do get problematic, I've rented a modem from them before and then they can't blame it on the 3rd party device. Once they get it fixed, then swap back to yours and return their modem.
BHerm24
This is a brand new modem out of box about a month ago. Also when first tech came out I took a screenshot and only errors I was getting on downstream was on channel 11 everything else was 0.
- BHerm24Jun 16, 2020Aspirant
This did only start once I had the new modem though too. So maybe I just need to send it back?
- plemansJun 16, 2020Guru - Experienced User
it could be the modem, it could be when the last tech was checking the line, they actually loosened something. Wouldn't be the first time
