brianm0122
Jun 03, 2020Aspirant
stray IP address
I have a C6900 set up as a gateway and DHCP server. I am using the default ip range (192.168.0.1-255). recently, during one of my periodical IP scans, a new IP address (192.168.100.1) popped up. It l...
Jun 03, 2020Guru - Experienced User
Its programming into all C series modems by default. You can access the gateway using that IP address, or if you conigure the modem for modem only mode, then you can use the .100.1 address to access the modems web page there as the .0.1 address will no longer be usable when in modem only mode.
antinode
Jun 03, 2020Guru
> [...] What is it, and where did it come from?
It's a DOCSIS standard, not specific to Netgear. You might try a Web
search for terms like, say:
192.168.100.1 DOCSIS
