chickeninferno
Mar 04, 2017Aspirant
Sudden Loss of Ethernet Ports C7000-100NAS
Hello Everyone, Roughly two days ago, my connection suddely dropped on my PS4 and computer roughly simultaneously (only two ethernet wired devices), while every wireless device continued to funct...
DarrenM
Mar 06, 2017Sr. NETGEAR Moderator
Hello Chickeninferno
Did you try the other 2 ports?
DarrenM
chickeninferno
Mar 06, 2017Aspirant
Yes I did. I also performed several factory resets from the software as well as the hard reset with the button on the back.
- DarrenMMar 09, 2017Sr. NETGEAR Moderator
You may want to contact support if the modem is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
