muralik
Aug 08, 2022Aspirant
Suddenly my Nighthawk CAX80 has stopped working.
Suddenly my Nighthawk CAX80 has stopped working. Power light is ON but the wireless functionality has stopped. Nothing to do with my Comcast provider. Please help.
Aug 08, 2022Guru - Experienced User
Are any other lights on?
If not, first try disconnecting the coax cable from it and doing a factory reset.
If that doesn't help, I'd contact support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
